Api session event editor panel set answer contents
API Endpoint: editorpanel/set_answer_contents.
API Endpoint name is Api session event editor panel set answer contents.
Use this endpoint to Set Answer (Panel) Contents
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (String) | String |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_answer_contents/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Text" ]'JavaScript example POST:
body: '[ 1, 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_answer_contents/", options)
