Api session event editor panel remove global
Revision as of 11:58, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorpanel/remove_global.
API Endpoint name is Api session event editor panel remove global.
Use this endpoint to Remove Global
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (GLOBAL Integer ID or multiple values in array [1, 2, 3]) Global
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_global/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_global/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/remove_global/", options)
