Api session event editor panel add answer
Revision as of 11:58, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorpanel/add_answer.
API Endpoint name is Api session event editor panel add answer.
Use this endpoint to Add Answer (Panel)
0 REQUIRED (PANEL Integer ID) Panel
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/add_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/add_answer/", options)
