Api session event editor netsetting set cluster fraction connected
API Endpoint: editornetsetting/set_cluster_fraction_connected.
API Endpoint name is Api session event editor netsetting set cluster fraction connected.
Use this endpoint to Set Cluster Fraction Connected
| 0 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '74'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '48'JavaScript example POST:
body: '74'
fetch("https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/", options)
