Api session event editor netload set building
API Endpoint: editornetload/set_building.
API Endpoint name is Api session event editor netload set building.
Use this endpoint to Set Building
| 0 | REQUIRED | (NET_LOAD Integer ID) | Net Load | |
| 1 | REQUIRED | (BUILDING Integer ID) | Building |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/set_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/set_building/", options)
