Api session event editor netload remove address
Revision as of 11:56, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editornetload/remove_address.
API Endpoint name is Api session event editor netload remove address.
Use this endpoint to Remove Address
0 REQUIRED (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) Net Load
1 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/remove_address/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/remove_address/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/remove_address/", options)
