Api session event editor measure set terrain height
Revision as of 11:54, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/set_terrain_height.
API Endpoint name is Api session event editor measure set terrain height.
Use this endpoint to Set the inner height of Terrain Spatial of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure IDs
1 REQUIRED (Integer number) Terrain Spatial ID
2 REQUIRED (Floating point number) Height value
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_terrain_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 86 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_terrain_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 31 ]'
JavaScript example POST:
 body: '[ 1, 1, 86 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_terrain_height/", options)
