Api session event editor measure remove event
Revision as of 11:54, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editormeasure/remove_event.
API Endpoint name is Api session event editor measure remove event.
Use this endpoint to Add a specific event of a Measure for a specific Action Type.
0 REQUIRED (MEASURE Integer ID or multiple values in array [1, 2, 3]) Measure ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Server Side (false = Client Side)
2 REQUIRED (ActionType or multiple values in array [a, b, c]) Action Type
3 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Event ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/remove_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true, "CONSTRUCTION_PLAN", 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/remove_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ], [ "CONSTRUCTION_PLAN", "CONSTRUCTION_PLAN_CANCEL", "CONSTRUCTION_PLAN_CANCEL" ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, true, "CONSTRUCTION_PLAN", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/remove_event/", options)
