Api session event editor indicator remove stakeholder
Revision as of 11:53, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorindicator/remove_stakeholder.
API Endpoint name is Api session event editor indicator remove stakeholder.
Use this endpoint to Remove Stakeholder
0 REQUIRED (INDICATOR Integer ID) Indicator
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorindicator/remove_stakeholder/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorindicator/remove_stakeholder/", options)
