Api session event editor global set point
API Endpoint: editorglobal/set_point.
API Endpoint name is Api session event editor global set point.
Use this endpoint to Set Point
| 0 | REQUIRED | (GLOBAL Integer ID) | Global | |
| 1 | REQUIRED | (Point with crs: EPSG:3857) | Point |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658667.5392305098, 6799344.831197374 ]
'Curl example multi item POST:
[ 1, {
"type" : "Point",
"coordinates" : [ 658759.1843578772, 6799402.7716219295 ]
'JavaScript example POST:
body: '[ 1, { "type" : "Point", "coordinates" : [ 658667.5392305098, 6799344.831197374 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_point/?crs=3857", options)
