Api session event editor cinematic add keypoint
Revision as of 11:50, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorcinematic/add_keypoint.
API Endpoint name is Api session event editor cinematic add keypoint.
Use this endpoint to Add Keypoint
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint/", options)
