Api session event editor area add with attribute
API Endpoint: editorarea/add_with_attribute.
API Endpoint name is Api session event editor area add with attribute.
Use this endpoint to Add With Attribute
| 0 | REQUIRED | (String) | String | |
| 1 | REQUIRED | (Floating point number) | Double |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", 31 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", 70 ]'JavaScript example POST:
body: '[ "Text", 31 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/", options)
