Api session event editor area add polygons
Revision as of 11:49, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorarea/add_polygons.
API Endpoint name is Api session event editor area add polygons.
Use this endpoint to Add polygons to existing Area
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Area
1 REQUIRED (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) MultiPolygon[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/add_polygons/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
Curl example multi item POST:
[ [ 1, 2, 3 ], [ {
 "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
JavaScript example POST:
 body: '[ 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_polygons/?crs=3857", options)
