Api session event editor address append attribute
Revision as of 11:48, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editoraddress/append_attribute.
API Endpoint name is Api session event editor address append attribute.
Use this endpoint to Appended to existing Address attribute value
0 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Attribute Values appended to existing values
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoraddress/append_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 1.0, "" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoraddress/append_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ], "" ]'
JavaScript example POST:
 body: '[ 1, "Attribute Name", 1.0, "" ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/append_attribute/", options)
