Api session event editor setting set permission popup active
API Endpoint: editorsetting/set_permission_popup_active.
API Endpoint name is Api session event editor setting set permission popup active.
Use this endpoint to Set Permission Popup Active
| 0 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_permission_popup_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_permission_popup_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'false'JavaScript example POST:
body: 'true'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_permission_popup_active/", options)
