Api session event editor setting get sun altitude
API Endpoint: editorsetting/get_sun_altitude.
API Endpoint name is Api session event editor setting get sun altitude.
Use this endpoint to Get Sun Altitude value for local Time in this Project
| 0 | REQUIRED | (Integer number) | Year | |
| 1 | REQUIRED | (Integer number) | Month | |
| 2 | REQUIRED | (Integer number) | Day | |
| 3 | REQUIRED | (Integer number) | Hour | |
| 4 | REQUIRED | (Integer number) | Minute | |
| 5 | REQUIRED | (Integer number) | Second |
| 200 | Double (Sun Altitude value) |
curl 'https://engine.tygron.com/api/session/event/editorsetting/get_sun_altitude/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 2013, 8, 2, 12, 0, 0 ]'JavaScript example POST:
body: '[ 2013, 8, 2, 12, 0, 0 ]'
fetch("https://engine.tygron.com/api/session/event/editorsetting/get_sun_altitude/", options)
