Api session event editor parametric remove plot attributes
API Endpoint: editorparametric/remove_plot_attributes.
API Endpoint name is Api session event editor parametric remove plot attributes.
Use this endpoint to Remove Plot Attributes
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) | Parametric Design | |
| 1 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Plot | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute name |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorparametric/remove_plot_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute name 1" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorparametric/remove_plot_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ "Attribute name 1", "Attribute name 2", "Attribute name 3" ] ]'JavaScript example POST:
body: '[ 1, 1, "Attribute name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorparametric/remove_plot_attributes/", options)
