Api session event editor overlay set water weather
API Endpoint: editoroverlay/set_water_weather.
API Endpoint name is Api session event editor overlay set water weather.
Use this endpoint to Set a specified Weather to serve as input for a specified water Overlay.
| 0 | REQUIRED | (OVERLAY Integer ID) | Water Overlay ID | |
| 1 | REQUIRED | (WEATHER Integer ID) | Weather ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_water_weather/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_water_weather/", options)
