Api session event editor overlay set service layer
Revision as of 11:28, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editoroverlay/set_service_layer.
API Endpoint name is Api session event editor overlay set service layer.
Use this endpoint to Set the Service layer names for a specified Service Overlay and Timeframe.
0 REQUIRED (OVERLAY Integer ID) Service Overlay ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Layer name(s)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_layer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Layer name 1" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_layer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "Layer name 1", "Layer name 2", "Layer name 3" ] ]'
JavaScript example POST:
 body: '[ 1, "Layer name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_service_layer/", options)
