Api session event editor overlay remove water weather
Revision as of 11:28, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editoroverlay/remove_water_weather.
API Endpoint name is Api session event editor overlay remove water weather.
Use this endpoint to Remove Water Weather
0 REQUIRED (OVERLAY Integer ID) Overlay
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_water_weather/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove_water_weather/", options)
