Api session event editor netload add and set node
API Endpoint: editornetload/add_and_set_node.
API Endpoint name is Api session event editor netload add and set node.
Use this endpoint to Add And Set Node
| 0 | REQUIRED | (NET_LOAD Integer ID) | Net Load | |
| 1 | REQUIRED | (Point with crs: EPSG:3857) | Point |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658669.169863148, 6799427.640250344 ]
'Curl example multi item POST:
[ 1, {
"type" : "Point",
"coordinates" : [ 658749.2641346161, 6799442.911951815 ]
'JavaScript example POST:
body: '[ 1, { "type" : "Point", "coordinates" : [ 658669.169863148, 6799427.640250344 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857", options)
