Api session event editor levee set default height
Revision as of 11:25, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorlevee/set_default_height.
API Endpoint name is Api session event editor levee set default height.
Use this endpoint to Set Default Height
0 REQUIRED (LEVEE Integer ID) Levee
1 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 67 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 50 ]'
JavaScript example POST:
 body: '[ 1, 67 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_default_height/", options)
