Api session event editor levee duplicate
Revision as of 11:25, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorlevee/duplicate.
API Endpoint name is Api session event editor levee duplicate.
Use this endpoint to Duplicate existing Levee
0 REQUIRED (LEVEE Integer ID or multiple values in array [1, 2, 3]) Levee
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editorlevee/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorlevee/duplicate/", options)
