Api session event editor geoplugin set new project
API Endpoint: editorgeoplugin/set_new_project.
API Endpoint name is Api session event editor geoplugin set new project.
Use this endpoint to Set New Project
| 0 | REQUIRED | (GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) | Geo Plugin | |
| 1 | REQUIRED | (Boolean or multiple values in array [true, false, true]) | Boolean[] |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_new_project/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_new_project/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'JavaScript example POST:
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/set_new_project/", options)
