Api session event editor excelsheet add
API Endpoint: editorexcelsheet/add.
API Endpoint name is Api session event editor excelsheet add.
Use this endpoint to Add new Excel Sheet
| 0 | REQUIRED | (String) | Name | |
| 1 | REQUIRED | (byte or multiple values in array [a, b, c]) | Byte array content | |
| 2 | REQUIRED | (String) | Uploader Name |
| 200 | Integer (Excel ID) |
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name", 1, "Uploader Name" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name", [ 1, 2, 3 ], "Uploader Name" ]'JavaScript example POST:
body: '[ "Name", 1, "Uploader Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorexcelsheet/add/", options)
