Api session event editor cinematic add keypoint with parameters
Revision as of 11:23, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorcinematic/add_keypoint_with_parameters.
API Endpoint name is Api session event editor cinematic add keypoint with parameters.
Use this endpoint to Add Keypoint With Parameters
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic
1 REQUIRED (Integer number) Integer
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Float[]
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Float[]
4 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Float[]
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_with_parameters/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1.0, 1.0, 1.0 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_with_parameters/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST:
 body: '[ 1, 1, 1.0, 1.0, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_with_parameters/", options)
