Api session event editor building query
Revision as of 11:22, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorbuilding/query.
API Endpoint name is Api session event editor building query.
Use this endpoint to Executes a single TQL query. Note: you can also use the session/query endpoint to execute multiple statements and get additional information on API usage.
0 REQUIRED (String) TQL Query Statement
1 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Value for update queries (optional)
200 Object (Object)
curl 'https://engine.tygron.com/api/session/event/editorbuilding/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "TQL Query Statement", "" ]'
JavaScript example POST:
 body: '[ "TQL Query Statement", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/query/", options)
