Api session event editor area generate water areas
API Endpoint: editorarea/generate_water_areas.
API Endpoint name is Api session event editor area generate water areas.
Use this endpoint to Generate Water Area
| 0 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '30'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '89'JavaScript example POST:
body: '30'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/", options)
