Api session event editor area generate sewer areas
Revision as of 11:22, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorarea/generate_sewer_areas.
API Endpoint name is Api session event editor area generate sewer areas.
Use this endpoint to Generate Sewer Area
0 REQUIRED (Integer number) Integer
1 REQUIRED (Floating point number) Double
2 REQUIRED (Floating point number) Double
3 REQUIRED (Floating point number) Double
4 REQUIRED (String) String
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 49, 66, 82, "Text" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 65, 60, 54, "Text" ]'
JavaScript example POST:
 body: '[ 1, 49, 66, 82, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/", options)
