Api session event editor area add with attribute
Revision as of 11:22, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorarea/add_with_attribute.
API Endpoint name is Api session event editor area add with attribute.
Use this endpoint to Add With Attribute
0 REQUIRED (String) String
1 REQUIRED (Floating point number) Double
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", 54 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", 84 ]'
JavaScript example POST:
 body: '[ "Text", 54 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/", options)
