Api session event editor start map creation
API Endpoint: eventeditor/start_map_creation.
API Endpoint name is Api session event editor start map creation.
API Endpoint to Set the Project's georeference center point to the provided coordinates and begin the process of automatically load in available data.
| 0 | REQUIRED | (Floating point number) | Center point (Longitude or X coordinate) | |
| 1 | REQUIRED | (Floating point number) | Center point (Latitude or Y coordinate) | |
| 2 | OPTIONAL | (MultiPolygon with crs: EPSG:3857) | Optional: Limit data loading to this Polygon | |
| 3 | OPTIONAL | (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) | Optional: Area of Interest Polygons |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editor/start_map_creation/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 6, 9, "", "" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editor/start_map_creation/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 24, 10, "", "" ]'JavaScript example POST:
body: '[ 6, 9, "", "" ]'
fetch("https://engine.tygron.com/api/session/event/editor/start_map_creation/?crs=3857", options)
