Api session event editor clear map
API Endpoint: eventeditor/clear_map.
API Endpoint name is Api session event editor clear map.
API Endpoint to Remove all geospatial data of the Project, such as Building, Area, etc.
| 0 | REQUIRED | (true, false) | Delete the map size and georeference too (false means deleting only the geodata) | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editor/clear_map/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'false'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editor/clear_map/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'JavaScript example POST:
body: 'false'
fetch("https://engine.tygron.com/api/session/event/editor/clear_map/", options)
