Api session event editor levee set description
API Endpoint to Set Description.
API Endpoint name is Api session event editor levee set description
| 0 | REQUIRED | (LEVEE Integer ID) | Levee | |
| 1 | REQUIRED | (String) | String |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'JavaScript Example POST:
body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_description/", options)
