Api session event editor levee set default width
Revision as of 09:42, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set Default Width.
API Endpoint name is Api session event editor levee set default width
0 REQUIRED (LEVEE Integer ID) Levee
1 REQUIRED (Floating point number) Double
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_width/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 47 ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_width/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 94 ]'
JavaScript Example POST:
 body: '[ 1, 47 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_default_width/", options)
