Api session event editor levee set default height
API Endpoint to Set Default Height.
API Endpoint name is Api session event editor levee set default height
| 0 | REQUIRED | (LEVEE Integer ID) | Levee | |
| 1 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 81 ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 90 ]'JavaScript Example POST:
body: '[ 1, 81 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_default_height/", options)
