Api session event editor levee remove side function
API Endpoint to Remove Side Function.
API Endpoint name is Api session event editor levee remove side function
| 0 | REQUIRED | (LEVEE Integer ID or multiple values in array [1, 2, 3]) | Levee |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/remove_side_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/remove_side_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript Example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorlevee/remove_side_function/", options)
