Api session event editor indicator remove
API Endpoint to Remove existing Indicator.
API Endpoint name is Api session event editor indicator remove
| 0 | REQUIRED | (INDICATOR Integer ID or multiple values in array [1, 2, 3]) | Indicator |
| 200 | Boolean (True when at least one item was removed) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorindicator/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorindicator/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript Example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorindicator/remove/", options)
