Api session event editor geotiff export
Revision as of 09:42, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Export GeoTIFF. For files larger than 2GB, use the Stream API..
API Endpoint name is Api session event editor geotiff export
0 REQUIRED (GEO_TIFF Integer ID) GeoTIFF ID
200 byte[] (byte array)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/export/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/export/", options)
