Api session event editor geolink remove additional
API Endpoint to Remove additional attribute injection from the created feature..
API Endpoint name is Api session event editor geolink remove additional
| 0 | REQUIRED | (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) | CustomGeo Link IDs | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute Names |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorgeolink/remove_additional/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name 1" ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeolink/remove_additional/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ] ]'JavaScript Example POST:
body: '[ 1, "Attribute Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/remove_additional/", options)
