Api session event editor building reset function values
API Endpoint to Reset Function Values.
API Endpoint name is Api session event editor building reset function values
| 0 | REQUIRED | (BUILDING Integer ID) | Building | |
| 1 | REQUIRED | (FunctionValue or multiple values in array [a, b, c]) | Function Value[] |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/reset_function_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "LIVABILITY_EFFECT" ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/reset_function_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "LIVABILITY_EFFECT", "CRITICAL_INFRASTRUCTURE", "NUM_CARS" ] ]'JavaScript Example POST:
body: '[ 1, "LIVABILITY_EFFECT" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/reset_function_values/", options)
