Api session event editor building query
API Endpoint to Executes a single TQL query. Note: you can also use the session/query endpoint to execute multiple statements and get additional information on API usage..
API Endpoint name is Api session event editor building query
| 0 | REQUIRED | (String) | TQL Query Statement | |
| 1 | OPTIONAL | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Value for update queries (optional) |
| 200 | Object (Object) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "TQL Query Statement", "" ]'JavaScript Example POST:
body: '[ "TQL Query Statement", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/query/", options)
