Api session event editor area generate water areas
Revision as of 09:39, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Generate Water Area.
API Endpoint name is Api session event editor area generate water areas
0 REQUIRED (Floating point number) Double
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '66'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '87'
JavaScript Example POST:
 body: '66'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/", options)
