Api session event editor clear map
API Endpoint to Remove all geospatial data of the Project, such as Building, Area, etc..
API Endpoint name is Api session event editor clear map
| 0 | REQUIRED | (true, false) | Delete the map size and georeference too (false means deleting only the geodata) | true or false |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editor/clear_map/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'JavaScript Example POST:
body: 'true'
fetch("https://engine.tygron.com/api/session/event/editor/clear_map/", options)
