Api session event editor activate testrun
Revision as of 09:39, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Start or stop a Scenario Testrun..
API Endpoint name is Api session event editor activate testrun
0 REQUIRED (true, false) Start the Scenario Testrun (false means stop) true or false
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editor/activate_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'
JavaScript Example POST:
 body: 'true'
fetch("https://engine.tygron.com/api/session/event/editor/activate_testrun/", options)
