Api session event editor zoning add
Revision as of 09:13, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add new Zoning
0 REQUIRED (true, false) Boolean true or false
200 Integer (Integer)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorzoning/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'false'
JavaScript Example POST:
 body: 'false'
fetch("https://engine.tygron.com/api/session/event/editorzoning/add/", options)
