Api session event editor weather set duration
Revision as of 09:13, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set how long the specified Weather's visualization lasts when it is Triggered.
0 REQUIRED (WEATHER Integer ID) Weather ID
1 REQUIRED (Floating point number) Duration of visualization in seconds
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorweather/set_duration/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 33 ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorweather/set_duration/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 21 ]'
JavaScript Example POST:
 body: '[ 1, 33 ]'
fetch("https://engine.tygron.com/api/session/event/editorweather/set_duration/", options)
