Api session event editor weather remove flood overlay
Revision as of 09:13, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Remove the specified visualization Overlay from specified Weather.
0 REQUIRED (WEATHER Integer ID or multiple values in array [1, 2, 3]) Weather ID
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorweather/remove_flood_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorweather/remove_flood_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorweather/remove_flood_overlay/", options)
