Api session event editor weather duplicate
API Endpoint to Create a copy of each specified Weather. The copies will have the same Setting and attributes, but can be edited independently of the originals.
| 0 | REQUIRED | (WEATHER Integer ID or multiple values in array [1, 2, 3]) | Weather IDs |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorweather/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorweather/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript Example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorweather/duplicate/", options)
