Api session event editor unitdataoverride add
Revision as of 09:12, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add new Unit Data Override
0 REQUIRED (UNIT_DATA Integer ID) Unit Data
200 Integer (Integer)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorunitdataoverride/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorunitdataoverride/add/", options)
