Api session event editor stakeholder select stakeholder
Revision as of 09:12, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Select Stakeholder with preferred ID, when not available fallback to next best.
0 REQUIRED (Integer number) Preferred Stakeholder ID or empty
1 REQUIRED (String) Client Token (from Join Session event)
200 Integer (Selected Stakeholder ID)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/select_stakeholder/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Client Token" ]'
JavaScript Example POST:
 body: '[ 1, "Client Token" ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/select_stakeholder/", options)
